TwinTurbo.NET: Nissan 300ZX forum - Re: Intake leak test
91z tt
on June 03, 2011 at 12:59 AM
Intake leak test
posted by OverZealous (CT)
on June 02, 2011 at 10:40 PM
Changed out all injectors. Conducted ohn test on all prior to install. I also tested them once installed thru the harness. Fuel pressure tested also - spot on.
Need help with wierd hestiation issue.
91z tt
07:32:30 06/02/11
Re: Need help with wierd hestiation issue.
BlackTwins
11:10:34 06/02/11
Re: Re: Need help with wierd hestiation issue.
91z tt
17:05:54 06/02/11
91z tt
17:08:45 06/02/11
Have you checked your timing? (n/m)
Stadsport (PHX)
15:17:24 06/02/11
Re: Have you checked your timing?
91z tt
17:06:22 06/02/11
How did you check it? (n/m)
Stadsport (PHX)
17:38:53 06/02/11
Re: How did you check it?
91z tt
18:35:43 06/02/11
K. Just wanted to make sure! (n/m)
Stadsport (PHX)
22:21:28 06/02/11
Are you able to swap out the VTC gears?
OverZealous (CT)
22:36:46 06/02/11
Fuel pressure test
OverZealous (CT)
22:37:43 06/02/11
Intake leak test
OverZealous (CT)
22:40:35 06/02/11
Re: Intake leak test -
91z tt
00:59:03 06/03/11
